Vacuum Table Kit
Vacuum Plenum Table Kit for PCNC 1100 Mills. Machined Cast Aluminum, 169 sq. inch surface area.
This vacuum table attaches to the center T-Slot of the PCNC 1100 Table. The kit can be used as-is or in conjunction with additional fixtures to create a custom vacuum work holding solution. Vacuum Pump not included.
- Machined Cast Aluminum Plate Construction
- 6 mm wide grid Channel, 1/4" Depth
- Dimensions: 17.75" x 9.5"x 1" (X,Y,Z)
- 10 Port Integrated Vacuum Channel
Learn More
