VCarve Pro
$699.00
VCarve Pro is a powerful but intuitive software solution for creating and cutting parts on a CNC Router.
VCarve Pro provides a powerful but intuitive software solution for creating and cutting parts on a CNC Router. VCarve Pro gives you the power to produce complex 2D patterns with profile, pocket, drill and inlay toolpaths, plus gives you the ability to create designs with v-carving textures as well as import and machine unlimited Vectric 3D clipart or single model files. The ‘Pro’ edition gives you unlimited job and toolpath size, true shape nesting & job set-up sheets, ideally suited to a production environment.
Features:
  • Ability to import 2D vector files and bitmap images
  • Complete set of 2D Design and Layout Tools
  • Import single 3D model files (STL, OBJ, 3DM, SKP etc.)
  • Import multiple Vectric 3D clipart files
  • 2D Toolpaths: Profiling, Pocketing, Drilling, Inlays and Quick Engraving
  • 2.5D Toolpaths: V-Carving, Prism Carving, Mouldings, Textures & Fluting
  • 3D Machining
  • Support for add-on gadgets
  • Ability to Merge Toolpaths
  • Toolpath Templates & Job Sheets
  • Ability to simulate the toolpaths
  • + FREE 2D + 3D Clipart worth $2000
  • Unlimited job and toolpath size
  • Photo VCarving toolpath strategy
  • Tool Database
  • Optimized clearance tools in VCarving
  • Built-in post processor
Requirements
  • Computer:
    • OS - Vista, 7, 8, 8.1 or Windows 10 with 4Gb RAM
    • Processor - 2 Ghz multi Core CPU
    • Ram - 4Gb
    • Hard Drive Space - 300 Mb Disk space (Program)
      • 7.7GB Additional disk space required if you wish to store the tutorials and clipart supplied, on your hard drive.
    • Display Resolution - 1024 x 768
Note: post processors for PathPilot are built in and do not require the installation of a separate post processor file.
What’s Included?
  • 1x License of VCarve Pro CAM software
