Water Chiller Kit
$549.95
28 lbs.
Currently Out of Stock
The Water Chiller Kit is recommended for use with High Speed Spindle Kit (PN 35178)
Water Chiller Kit. For use with 24000 RPM High Speed Spindle
- Voltage: 115V
- Current: 1A
- Cooling Capacity: 50W/°C
- Resevoir: 2.4 Gallons
- Max Flow: 2.6 Gallons/min
- Dimensions: 18.5 in. x 11 in. x 14.5 in. (L x W x H)
- Low Flow Alarm
- Digital Temperature Display
- 8 mm Quick Connect Fittings
