Wireless Probe and Tool Setter Kit
Wireless probe and tool setter kit contains: probe, toolsetter, and optical receiver compatible with the 1500MX CNC Mill.
What's in the box:
Probe
- Probe body (51782) (with installed pull stud 37553)
- 4 batteries, 3.6V, 1200 mAh, 1/2AA, Li-SOCl2
- (51783) BT30 Tool Holder, Probe, Wireless
- Cleaning cloth
- Hardware kit:
- 1x Replacement Battery Cover O-ring
- 1x 2mm allen key
- 1x Stylus Pin Wrench (S-10-202)
- 1x Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread (51781)
- 1x Calibration Ring
Toolsetter
- Toolsetter with M12 mounting bolt and T Nut
- Cleaning cloth
- Wrenches
- Stylus Pin Wrench (S-10-202)
- 1.5mm, 2mm, 2.5mm and 3mm allen wrenches.
- Hardware kit
- 2x Stylus Leashes
- 1x Stylus Extension
- (51595) Toolsetter Stylus, 1/2IN Diameter (installed in toolsetter)
- 1x Calibration Gage
Optical receiver
- Receiver with wiring harness for plug-and-play installation
- Hardware kit
- 4x M4x0.7-8 Socket head cap screws
- 2x velcro cable straps
- 1x Mount
Using a probe and toolsetter dramatically shortens setup time and increases accuracy and reliability when measuring tool lengths and setting work offset coordinate systems. PathPilot’s intuitive user interface includes routines to measure tool lengths and determine work coordinate offsets from a variety of standard part features (boss, pocket, corner). Additionally, PathPilot includes pre-written macros that allow you to easily add tool measurement to your existing G-code programs.
For more complicated workflows, CAM software like Fusion 360 or SprutCAM can be used to automate WCS setting on complex geometries or conduct in-machine part inspection.
Note: Tormach does not currently sell replacement batteries for this item. You can source replacment batteries with the following battery specifications - 1200 mAh, 1/2AA, Li-SOCl2
Probe:
- Stylus sensing direction: ±X, ±Y, +Z
- Stylus sensing over over-travel : X-Y±12°, Z +5 mm
- Trigger force in Z direction: 500g -1000g
- Trigger force in X X-Y surface: 50g -100g
- Unidirectional repeatability (2σ): ≤ 1µm
- Optical signal receiving/sending distance: ≤ 5m
- Working days of new batteries ( 5% utilization rate in a single shift): 90 -140 days
- IP68 waterproof rating
- Battery specification: 14250, 3.6V, 1000mAh - 2 pcs.
Toolsetter:
- Stylus sensing over over-travel : X X-Y±5mm, Z -5 mm
- Repeatability (2σ): ≤ 1µm
- Optical signal sending distance: 3-5m
- Working days of new batteries (5% utilization rate in a single shift): 90-140 days
