xsTECH CNC Router/Mill
xsTECH Router Package $4,195.00
xsTECH Router 4th Axis Kit $669.00
xsTECH Router Shipping Case $1,119.00
Additional Options:
xsTECH Router - 230V (Europe) $4,195.00
Additional Options:
Tormach xsTECH Aluminum Fixture Tooling Plate $113.00
xsTECH Cutting Tool Kit $219.00
Replacement set of the same tool kit included with every xsTECH purchase.
xsTECH Router Wrench Set $15.95
30° x 1/8 in. x 1-1/2 in. $18.95
45° x 1/8 in .x 1-1/2 in. $18.95
60° x 1/8 in. x 1-1/2 in. $18.95
90° x 1/8 in. x 1-1/2 in. $18.95
ER11 Collet Set (7 Pcs.) - Inch $27.95
Anti-Fatigue Tormach Logo Mat $58.95
36 in. x 24 in. Satin Tormach Banner with Top Grommets $27.95
PathPilot Keyboard Shortcuts Mousepad $16.95
* Required Fields
xsTECH TECHNICAL SPECIFICATIONS
X-Axis: 8.6 in. (220 mm)
Y-Axis: 6.3 in. (160 mm)
Z-Axis: 2.4 in. (61 mm)
Spindle Power: 120 W (0.12 kW)Brushless DC
Maximum Speed: 20,000 RPM
Spindle Taper: ER11
Noise Level (No Load Operation): <66 db(A)
Repositioning Accuracy: 0.004 in (0.10 mm)
Power Required: Single-Phase, 50-60 Hz
120 Vac (USA/Canada, PN 39177)
230 Vac (International, PN 50614)
Table Size: 12.6 in. × 5.9 in.(320 mm × 150 mm)
Typical System Footprint: 15.4 in. × 15.7 in.
(391 mm × 399 mm)
Overall System Height: 16.7 in. (424 mm)
Typical System Weight: 33 lb (14.9 kg)
Maximum Table Load Weight: 6.6 lb (3 kg)
1-Year Warranty against defects in material and workmanship.
