xsTECH CNC Router
The xsTECH Router is a desktop CNC ready to use out of the box. Ideal for social distance learning, craftrooms or makerspaces. It's capable enough to cut all manners of plastics, woods, and even aluminum.
Note: This item has a flat fee shipping fee inside the contiguous United States. This includes shipping to a US port of customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
Looking for Documentation & Help? Check Out: xsTECH Technical Support & Knowledge Base |
Your xsTECH CNC Router Package includes:
- 10.4 in. Touchscreen PathPilot Controller
- Keyboard, Mouse, and Jog Shuttle input devices
- WiFi Module
- Electronic Tool Setter
- ER11 Collets
- 16 pcs. Carbide Cutting Tools
- 1 - Spiral 'O' Flute Up-Cut End Mill: 2 mm x 12 mm x 4 mm x 50 mm
- 1 - Spiral Down-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- 1 - Spiral Up-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- 1 - Spiral Compression End Mill: 4 mm x 20 mm x 4 mm x 50 mm
- 1 - Spiral Down-Cut End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- 1 - Spiral Ball Nose Up-Cut End Mill: 2 mm x 12 mm x 4 mm x 50 mm
- 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 25 mm x 4 mm x 50 mm
- 1 - Spiral 'O' Flute Down-Cut End Mill: 4 mm x 25 mm x 4 mm x 50 mm
- 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- 1 - Straight Ball Nose End Mill: 4 mm x 25 mm x 4 mm x 50 mm
- 1 - Tapered Ball Nose End Mill: 1 mm x 10 mm x 4 mm x 50 mm
- 1 - Square End Mill: 4 mm x 6 mm x 4 mm x 50 mm
- 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 8 mm x 4 mm x 30 mm
- 1 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 6 mm x 4 mm x 40 mm
- 1 - Spiral 'O' Flute Up-Cut End Mill: 2 mm x 6 mm x 4 mm x 40 mm
Looking for Documentation & Help? Check Out: Technical Support & Knowledge Base
Table size | 12.6 in. x 5.9 in. |
Working area (XYZ) | 8.6 in. x 6.3 in. x 2.4 in. |
Spindle | ER11 Collets - 5000-20000 RPM - 125W BLDC direct drive |
Weight | Main unit - 33 lbs. |
Voltage Input | 120 vac, 50/60 Hz (Note: 230V available. See PN 50614) |
Motion | Belt drive, maximum speed 120 IPM |
