xsTECH Cutting Tool Kit
$199.95
Replacement tool kit for the xsTech Router
Kit contains one each of the following:
- PN 39167 - Spiral 'O' Flute Up-Cut End Mill: 2 mm x 12 mm x 4 mm x 50 mm
- PN 39176 - Spiral Down-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- PN 39175 Spiral Down-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- PN 39174 - Spiral Up-Cut Plunge End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- PN 39173 - Spiral Compression End Mill: 4 mm x 20 mm x 4 mm x 50 mm
- PN 39172 - Spiral Down-Cut End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- PN 39171 - Spiral Ball Nose Up-Cut End Mill: 2 mm x 12 mm x 4 mm x 50 mm
- PN 39170 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 25 mm x 4 mm x 50 mm
- PN 39169 - Spiral 'O' Flute Down-Cut End Mill: 4 mm x 25 mm x 4 mm x 50 mm
- PN 39168 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 12 mm x 4 mm x 50 mm
- PN 39166 - Straight Ball Nose End Mill: 4 mm x 25 mm x 4 mm x 50 mm
- PN 39165 - Tapered Ball Nose End Mill: 1 mm x 10 mm x 4 mm x 50 mm
- PN 39164 - Square End Mill: 4 mm x 6 mm x 4 mm x 50 mm
- PN 39163 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 8 mm x 4 mm x 30 mm
- PN 39162 - Spiral 'O' Flute Up-Cut End Mill: 4 mm x 6 mm x 4 mm x 40 mm
- PN 39161 - Spiral 'O' Flute Up-Cut End Mill: 2 mm x 6 mm x 4 mm x 40 mm
