ZA6 Robot Solenoid Valve Kit
$235.90
5 lbs.
2-valve DC 24V pneumatic solenoid kit for ZA6 robot.
2-valve 24V pneumatic solenoid kit for ZA6 robot. Comes with M12 electrical connector and 4mm push-to-connect airline fittings for plug and play connection to the ZA6 robot outputs and pneumatic gripper accessories. Mounting plate with holes spaced to match threaded PEM fasteners allows you to mount this to the side of the ZA6 electrical cabinet.
Specifications:
  • Type: Two-position five-way valve
  • Input voltage: 24VDC±10%
  • Rated power: 3W per valve
  • Pressure:0.15-0.8MPa (21.75-116 psi)
  • Working temperature:-20-70℃
  • Waterproof: IP67
