Don't forget about slitting saws when you have a part that calls for a deep slot. With a slitting saw, slots with a large depth-to-width ratio can be made both faster and straighter than with a long and skinny endmill. There are two slitting saw arbor sizes available in our TTS toolholder lineup: 1" and 1/2". These are keyless arbors, so they will work with both keyed and keyless slitting saws. We also have a selection of HSS slitting saws to fit these arbors.
More Tormach Fab Lab Videos:
- How to Setup a 2-Jaw Chuck on a 4th Axis
- How to Setup a 3-Jaw Chuck on a 4th Axis
- How to Setup a 4-Jaw Chuck on a 4th Axis
- Toolmaker Vises Tips
- How to use a Coaxial Indicator
- Fixture Plate Basics
- Getting Started with Tension/Compression Tapping
- Getting Started with Auto-Reversing Tapping
- How to Swing Indicate a Square
- How to Swing Indicate a Circle
- How to Bore an OD
- How to Bore an ID
- How to Use a Sine Vise
- Tips for using Strap Clamps
- How to Square a Block
