1100M Basic EDU Bundle
1100M Mill This product is required for the machine. $12,995.00
1100M Printed Manual $23.95
1100M / 1100MX Stand This product is required for the machine. $2,669.00
1100M Chip Tray This product is required for the machine. $589.00
1100M Enclosure Kit This product is required for the machine. $3,655.00
Door Lock Switch Kit This product is required for the machine. $349.00
Manual Oil Pump This product is required for the machine. $100.95
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
Lifting Bar Kit $230.00
PathPilot Controller This product is required for the machine. $975.00
PathPilot Controller Vesa Mount This product is required for the machine. $20.00
Standard LCD Monitor This product is required for the machine. $335.00
Jog Shuttle Controller This product is required for the machine. $118.00
Controller Arm This product is required for the machine. $429.00
5 in. (127 mm) Parallel Set $58.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,399.00
ER20 Collet Set (15 Pcs.) - Inch $118.00
Drawbar Wrench/Hammer $37.95
Compact TTS™ Tool Tightening Fixture $54.95
1/2 in. Shank Edge Finder $17.95
3/8 in. Shank Edge Finder $16.95
1100M Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
PATHPILOT® Controller
80GB program memory
Assembly
1100M Assembly is available for $2,995 .
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
