15L Slant-PRO Lathe Starter Package
15L Slant-PRO CNC Lathe This product is required for the machine. $20,450.00
Lathe Test Piece Kit This product is required for the machine. Lathe Test Piece Kit
Sealant, Sikaflex 1a, 300mL Cartridge, Black This product is required for the machine. Sealant, Sikaflex 1a, 300mL Cartridge, Black
Cord, Power 115 VAC 18AWG 6ft This product is required for the machine. Cord, Power 115 VAC 18AWG 6ft
Cable, Monitor Power Extension 6 ft (combo male/female end) This product is required for the machine. Cable, Monitor Power Extension 6 ft (combo male/female end)
Power Strip 3 AC Kit for 15L This product is required for the machine. Power Strip 3 AC Kit for 15L
Related items:
How to choose your oiler
How to choose your oiler?
Oilers
Manual Oil Pump $100.95
Additional Options:
Automatic Oiler Kit (230V) for PCNC 1100 / 15L $755.00
Additional Options:
15L Printed Manual $23.95
Light Kit for Tormach 15L Slant-PRO $190.00
Lifting Kit for Tormach 15L Slant-PRO $395.00
Buck-Boost Transformer $276.00
California Air Tools 4610XC Air Compressor $399.00
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $975.00
$48.95
Waterproof Mini-Keyboard $48.95
$28.95
Waterproof Mouse $28.95
Standard LCD Monitor $335.00
Touch Screen Kit $545.00
Jog Shuttle Controller $118.00
Controller Arm $429.00
USB M-Code I/O Interface Kit $309.00
Recommended items:
Floating Tramp Oil Collection Pillow $15.95
Gang Tool Coolant Accessory Kit, 15L Slant-PRO $107.00
Turret Kit for Tormach 15L Slant-PRO $4,995.00
9 Inch Length Coolant Nozzle for Turret 10-Pack $58.95
Boring Bar Holder for Turret (Unfinished Bore) $208.00
Boring Bar Holder for Turret $355.00
OD Turning/Facing Holder for Turret $297.00
Recommended items:
Automatic Collet Closer for 15L Slant-PRO $2,845.00
Collet Closer Foot Pedal Kit $179.00
Recommended items:
Quick Change Tool Post Kit for Tormach 15L Slant-PRO Lathe $999.00
EZ-Puller with 3/4 $969.00
Lathe Tool Starter Kit #1 $268.00
OD Threading Tool: CER0750K16 $66.95
ER20 Collet Chuck $46.95
ER20 Collet Set (15 Pcs.) - Inch $118.00
Plain Center Drill Set $15.95
1/16 in. - 1/2 in. Jobber Length Drill Set (by 64ths) $152.00
Deluxe Lathe Tool Starter Kit $1,165.00
8-Piece STFCR Stub Boring Bar Set $274.95
SprutCAM OEM Lathe (Online) $895.00
More Info In Stock
More Info In Stock
Free SprutCAM 3 Month Trial
More Info In Stock
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) $585.00
4-Jaw Independent Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) $465.00
15L Manual 5C Drawtube $253.00
5C Round Collet Set (18 Pcs.) - Inch $179.00
5C Adjustable Collet Stop $15.95
Recommended items:
6 in. Face Plate (D1-4 Type Direct Mount) $276.00
15L Slant-PRO Extended Warranty $795.00
More Info In Stock
More Info In Stock
On-site Service Quote Request
On-site machine installation and training is available for an additional charge ($2,000 reservation fee + $2,000 per day of service) when purchasing a new machine. Check the box to quote this service.
Stop-Loc Setup Tool $20.95
Haimer CENTRO Precision Centering Device $835.00
2 mm Straight Probe Tip for Haimer CENTRO $83.95
5 mm Straight Probe Tip for Haimer CENTRO $73.95
5 mm Bent Probe Tip for Haimer CENTRO $98.95
Recommended items:
Anti-Fatigue Tormach Logo Mat $58.95
PathPilot Keyboard Shortcuts Mousepad $16.95
36 in. x 24 in. Satin Tormach Banner with Top Grommets $27.95
* Required Fields
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
15L Slant-PRO CNC Lathe assembly pricing is available for $2,995
Motion
Spindle Speed:
Control
8-Station turret
Gang tooling system
Assembly
