24R Advanced EDU Bundle
24R CNC Router This product is required for the machine. $14,995.00
Standard Height Adjustable Machine Foot This product is required for the machine.
More Info Stock: In Stock
1HP Dust Collector with 30 micron bag filter This product is required for the machine. $409.95
Dust Collection Hose, 4 This product is required for the machine.
24R Printed Manual $19.95
Grease, Hiwin G-05, 400g $41.95
24R Router PathPilot Operator Console This product is required for the machine. $1,795.00
Cable, Ethernet, Cat5e, 10 feet long, 24R This product is required for the machine.
Enclosure Left Light Power Cable This product is required for the machine.
Electronic Tool Setter for 24R This product is required for the machine. $295.00
Storm Vacuum Pump for 24R This product is required for the machine. $1,695.95
Storm Vacuum System Canister Filter This product is required for the machine.
Storm Vacuum Adapter Kit for 24R This product is required for the machine. $149.95
Gasket, 5/16 in. Vacuum Neoprene Foam, 20 Feet This product is required for the machine. $39.95
ER20 Collet Set (30 Pcs.) - Inch $249.95
Huot ER20 Collet Rack $69.95
Spring-Loaded CNC Drag Knife $169.95
24R Starter Cutting Tool Kit by Amana Tools $499.95
24R Automatic Tool Changer This product is required for the machine. $5,994.95
ISO20 CNC Operator Set (Inch) This product is required for the machine. $729.95
24R Extended Warranty $795.00
* Required Fields
TECHNICAL SPECIFICATIONS
X-Axis: 24.75 in. (625 mm)
Y-Axis: 55.75 in. (1415 mm)
Z-Axis: 6.70 in. (170 mm)
Spindle Power: 2 hp / 1.5 kW
Spindle Type: Electrospindle
Minimum Speed: 10,000 RPM
Maximum Speed: 24,000 RPM
Thread Machining: Thread Mill
Power Required
Machine Specs
Linear Motion
Construction
Machine Base: Cast Iron
Gantry: Aluminum
Resolution & Accuracy
PATHPILOT® Controller
80GB program memory
Assembly
