24R Basic EDU Bundle
24R CNC Router This product is required for the machine. $15,950.00
24R Printed Manual $22.95
Grease, Hiwin G-05, 400g $48.95
Cable, Ethernet, Cat5e, 10 feet long, 24R This product is required for the machine.
Enclosure Left Light Power Cable This product is required for the machine.
PathPilot Controller This product is required for the machine. $1,015.00
Standard LCD Monitor This product is required for the machine. $319.00
Controller Arm This product is required for the machine. $409.00
PathPilot Controller Vesa Mount This product is required for the machine. $22.95
Jog Shuttle Controller This product is required for the machine. $113.00
Electronic Tool Setter for 24R This product is required for the machine. $319.00
ER20 Collet Set (15 Pcs.) - Inch $113.00
24R Starter Cutting Tool Kit by Amana Tools $535.00
24R Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
24R CNC ROUTER TECHNICAL SPECIFICATIONS
X-Axis: 24.75 in. (625 mm)
Y-Axis: 55.75 in. (1415 mm)
Z-Axis: 6.70 in. (170 mm)
Spindle Power: 2 hp / 1.5 kW
Spindle Type: Electrospindle
Minimum Speed: 10,000 RPM
Maximum Speed: 24,000 RPM
Thread Machining: Thread Mill
Power Required
Machine Specs
Linear Motion
Construction
Machine Base: Cast Iron
Gantry: Aluminum
Resolution & Accuracy
PATHPILOT® Controller
80GB program memory
Assembly
24R CNC Router Assembly is available for $2,995 .
Power Required
Machine Specs
Linear Motion
Construction
Gantry: Aluminum
80GB program memory
Assembly
Assembly for the 24R is available for $2,995
