770M Advanced EDU Bundle
770M Mill This product is required for the machine. $9,950.00
770MX / 770M  Stand This product is required for the machine. $2,565.00
770M Enclosure Kit This product is required for the machine. $3,259.00
770M Chip Tray This product is required for the machine. $449.00
Door Lock Switch Kit This product is required for the machine. $335.00
Lifting Bar Kit $221.00
Automatic Oiler Kit (115V) for 770M / 770MX This product is required for the machine. $725.00
770M Mill Printed Manual $22.95
770M/M+/MX PathPilot Operator Console This product is required for the machine. $2,245.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $565.00
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $319.00
Portable Refractometer - Coolant Tester $22.95
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,345.00
10-Pocket Automatic Tool Changer for the 770M This product is required for the machine. $5,995.00
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $96.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,345.00
End Mill Kit for Aluminum #1 $535.00
TTS™ Mini-Shear .750 in. $329.00
XDET 2.522 (Mini-Shear) Insert 10-Pack $258.00
ER20 Collet Set (30 Pcs.) - Inch $286.00
5 in. (127 mm) Parallel Set $56.95
Huot ER20 Collet Rack $79.95
1/16 in. - 1/2 in. Machine Length Drill Set $211.00
Modular Tension/Compression Tapping Head Kit $519.00
TTS™ Diamond Drag Engraver Kit $113.00
Passive Probe Kit $489.00
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $113.00
Electronic Tool Setter with Mounting Block $1,495.00
PathPilot Software Bootable USB Drive - Recovery Media $28.95
770M Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
770M TECHNICAL SPECIFICATIONS
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Machine Dimensions
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
770M Assembly is available for $2,995 .
PATHPILOT® Controller
Technical Specifications
Spindle Taper: R8
Maximum Feed Rate
Machine Dimensions
Assembly
