770MX Premium Package
770MX Mill This product is required for the machine. $23,450.00
770MX Enclosure Kit
770MX Enclosure Kit This product is required for the machine. 770MX Enclosure Kit
770MX Chip Tray
770MX Chip Tray This product is required for the machine. 770MX Chip Tray
770MX / 770M Stand
770MX / 770M  Stand This product is required for the machine. 770MX / 770M Stand
Related items:
Anti-Fatigue Tormach Logo Mat $58.95
PathPilot Keyboard Shortcuts Mousepad $16.95
36 in. x 24 in. Satin Tormach Banner with Top Grommets $27.95
How to choose your oiler
How to choose your oiler?
Oilers
Manual Oil Pump $100.95
Additional Options:
Automatic Oiler Kit (115V) for 770M / 770MX $755.00
Additional Options:
Lifting Bar Kit $230.00
Door Lock Switch Kit $349.00
California Air Tools 4610XC Air Compressor $399.00
770MX Printed Manual $23.95
770M/M+/MX PathPilot Operator Console
770M/M+/MX PathPilot Operator Console $2,339.00
$28.95
Waterproof Mouse $28.95
$48.95
Waterproof Mini-Keyboard $48.95
Additional Options:
PathPilot Controller
PathPilot Controller $995.00
$28.95
$48.95
Touch Screen Kit $545.00
Jog Shuttle Controller $118.00
Controller Arm $429.00
Additional Options:
Passive Probe Kit (BT30) $519.00
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $118.00
5 pin DIN extension cable, 6 ft $16.95
Recommended items:
Haimer 3D Sensor Kit (BT30) $579.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $61.95
Recommended items:
Electronic Tool Setter with Mounting Block $1,559.00
1/2 in. Shank Edge Finder $17.95
3/8 in. Shank Edge Finder $16.95
Laser Edge/Center Finder (Bullseye) $213.00
Laser Edge/Center Finder (Center Spot) $213.00
Coolant
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX $589.00
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 $335.00
Portable Refractometer - Coolant Tester $23.95
SmartCool Starter Kit $825.00
Additional Options:
FogBuster Coolant Kit (115 Vac) for 770M/770MX $685.00
Additional Options:
10-Pocket Automatic Tool Changer for the 770MX (BT30) $5,995.00
microARC 4 - 100 mm 4th Axis
remove
$3,639.95
4th Axis Driver and Installation Kit (M/MX)
microARC 4 Subplate $118.00
Additional Options:
6 in. Tilting Motorized Rotary Table
remove
$2,784.95
2 Jaw Chuck for 6 in. Table $355.00
3 Jaw Chuck for 6 in. (152 mm) Table $465.00
4 Jaw Chuck for 6 in. Table $465.00
Adjustable Tailstock (Medium) $179.00
RapidTurn Starter Package
remove
$3,450.00
Additional Options:
RapidTurn Deluxe Package
remove
$4,450.00
Additional Options:
770MX Extended Warranty $995.00
More Info In Stock
More Info In Stock
On-site Service Quote Request
On-site machine installation and training is available for an additional charge ($2,000 reservation fee + $2,000 per day of service) when purchasing a new machine. Check the box to quote this service.
6 in. TalonGrip™ Vise Jaw Systems  - Mitee-Bite - Compatible with Tormach 4 in. and 5 in. vises $201.00
VersaGrip™ Vise Jaws - Mitee-Bite - Compatible with Tormach 4 in. and 5 in. vises $232.00
Standard 5 in. Steel Step Jaw Set $70.95
Standard 5 in. Aluminum Soft Jaw Set $24.95
Extended 5 in. Aluminum Soft Jaw Set $35.95
Extra Tall 5 in. Steel Jaw Set $58.95
XL 5 in. Aluminum Soft Jaw Set $55.95
Multi-V 5 in. Jaw Set $140.00
Professional Vise Jaw Set $355.00
Professional Vise Jaw Set w/ Pin Jaw $455.00
5 in. (127 mm) Pin Jaw Set $235.00
5 in. (127 mm) Parallel Set $58.95
Adjustable Parallel Set $51.95
Work Stop $58.95
2pc Vise Alignment Keys with Screws for 4 in. & 5 in. CNC Vise $23.95
Recommended items:
4 in. CNC Vise $445.00
4 in. Parallel Set $58.95
Wavy Parallel Set $58.95
Work Stop $58.95
Recommended items:
Work Stop $58.95
Recommended items:
5/8 in. T-Slot Nut with Locating Pin (Blind) $14.95
5/8 in. T-Slot Nut with Locating Pin $14.95
5/8 in. T-Slot Nut with Locating Stop $12.95
T-Slot Clamp Set $140.00
5/8 in. T-Slot Nut $7.95
1/2-13 Flanged Nut $4.95
Recommended items:
SMW Fixture Tooling Plate for 770 Mills
Includes fixture tooling plate (PN 38209) bundled with mounting hardware and the most popular fixturing accessories (PN 52311).
Fixture Tooling Plate Accessory Upgrade Kit $635.00
770 Fixture Tooling Plate Accessory Kit $585.00
Related items:
Modular Vacuum Chuck Kit $355.00
YG-1 V7 Plus A Series Steel, Cast Iron & Stainless End Mill Kit $705.00
BT30 Operator's Kit (Inch) $1,455.00
Starter BT30 Toolholding Set
BT30 Tool Holder, Drill Chuck 8mm, 80mm $124.00
BT30 Tool Holder, End Mill 1/4 in, 50mm $63.95
BT30 Tool Holder, End Mill 3/8 in, 50mm $63.95
BT30 Tool Holder, End Mill 1/2 in, 50mm $63.95
BT30 Tool Holder, ER20, 48mm Guage Length $67.95
30 mm Wrench for TTS™-ER20 Nut $10.95
Socket, BT30 Pull Stud $58.95
ER20 Collet - 1/8 in. $11.95
ER20 Collet - 1/4 in. $11.95
ER20 Collet - 3/8 in. $11.95
Pull Stud, BT30 45-Degree $8.95
ER20 Toolholder 5 Pack
BT30 Tool Holder, ER20, 60mm Gage Length $64.95
ER16 Toolholder 5 Pack
BT30 Tool Holder, ER16, 60mm Gage Length $67.95
ER16M Collet Nut Wrench $19.95
ER20 Collet Variety Pack (20 Pcs.) - Inch
ER20 Collet - 1/2 in. $11.95
ER16 Collet Variety Pack (15 Pcs.) - Inch
ER16 Collet - 1/8 in. $11.95
ER16 Collet - 1/4 in. $11.95
ER16 Collet - 3/8 in. $11.95
BT30 Tool Holder, End Mill 3/8 in, 50mm 2  x  $63.95
ER20 Collet - 1/8 in. 2  x  $11.95
ER20 Collet - 1/4 in. 2  x  $11.95
ER20 Collet - 3/8 in. 2  x  $11.95
Pull Stud, BT30 45-Degree 10  x  $8.95
ER20 Collet - 1/2 in. 5  x  $11.95
BT30 Tool Holder, ER20, 48mm Guage Length 5  x  $67.95
BT30 Tool Holder, ER16, 60mm Gage Length 5  x  $67.95
ER16 Collet - 1/8 in. 5  x  $11.95
ER16 Collet - 1/4 in. 5  x  $11.95
BT30 Tool Holder, End Mill 1/8 in, 50mm 5  x  $63.95
ER16 Collet - 3/8 in. 5  x  $11.95
ER16 Collet Set (22 Pcs.) - Inch $235.00
ER20 Collet Set (15 Pcs.) - Inch $118.00
ER20 Collet Set (30 Pcs.) - Inch $297.00
ER32 Collet Set (6 Pcs.) - Inch $109.00
ER32 Collet Set (12 Pcs.) - Inch $219.00
Huot ER16 Collet Rack $82.95
Huot ER20 Collet Rack $82.95
BT30 Operator's Kit (Metric) $1,455.00
BT30 Tool Holder, End Mill 6mm, 50mm Gage Length $60.95
BT30 Tool Holder, End Mill 10mm, 50mm Gage Length $60.95
ER20 Collet - 4 mm $11.95
ER20 Collet - 6 mm $11.95
ER20 Collet - 10 mm $11.95
BT30 Tool Holder, End Mill 6mm, 50mm Gage Length 2  x  $60.95
BT30 Tool Holder, End Mill 10mm, 50mm Gage Length 2  x  $60.95
ER20 Collet - 4 mm 2  x  $11.95
ER20 Collet - 6 mm 2  x  $11.95
ER20 Collet - 10 mm 2  x  $11.95
Pull Stud, BT30 45-Degree 5  x  $8.95
Socket, BT30 Pull Stud 16  x  $58.95
ER16 Collet Set (12 Pcs.) - Metric $174.00
ER20 Collet Set (14 Pcs.) - Metric $257.00
ER32 Collet Set (12 Pcs.) - Metric $257.00
Related items:
Related items:
Related items:
Related items:
Related items:
Related items:
BT30 Tool Holder, ER16M (Mini-Nut), 60mm Gage Length
Related items:
Related items:
BT30 Tool Holder, ER20M (Mini-Nut), 60mm Gage Length
ER20M Collet Nut Wrench $20.95
Related items:
BT30 Tool Holder, ER32, 60mm Gage Length
Related items:
Face Mill 38mm Kit
Face Mill - 38 mm $224.00
$87.95
BT30 Tool Holder, Face Mill Arbor 1/2 in, 35mm $87.95
$8.95
Carbide Insert for Steel - Face & End Mills 10-Pack $51.95
Carbide Insert for Aluminum and Plastic - Face & End Mills 10-Pack $152.00
Related items:
Shear-Hog - 2 in. Tooling Bundle
More Info In Stock
Shear-Hog - 2 in. $445.00
$87.95
$8.95
ADEH 431 (Shear-Hog) Insert 10-Pack $235.00
ADEH 434 (Shear-Hog) Insert 10-Pack $235.00
Related items:
Shearhog 1 in. Tooling Bundle
More Info In Stock
Shear-Hog - 1 in. MIT Cutting Head $257.00
BT30 Tool Holder, Modular, M12, 50mm $85.95
Related items:
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. Tooling Bundle
More Info In Stock
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. $309.00
BT30 Tool Holder, Modular, M6, 50mm $82.95
Milling Insert: EOHW060220ZTR (DIJET QM MINI) 10-Pack $197.00
Milling Insert: EOMW060210ZER (DIJET QM MINI) 10-Pack $112.00
Related items:
Recommended items:
Dial Test Indicator Kit $190.00
Digital Micrometer (0-1 in.) $70.95
IP54 OriginCal Absolute Digital Calipers 0 to 6 in. $64.95
Stop-Loc Setup Tool $20.95
1-2-3 Block Set $29.95
More Info In Stock
More Info In Stock
Free SprutCAM 3 Month Trial
More Info In Stock
USB M-Code I/O Interface Kit $309.00
* Required Fields
X-Axis: 14 in. (356 mm)
Y-Axis: 7.5 in. (191 mm)
Z-Axis: 13.25 in. (337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 250 IPM (6.35 m/min)
Power Required: Single-Phase 115 Vac, 50/60Hz, 15A breaker
Frame
Table Size: 26 in. × 8 in. (660 mm x 203 mm)
Spindle Centerline to Machine Column: 8.6 in. (218 mm)
Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
Overall System Height: 88 in. (2235 mm)
Typical System Weight: 950 lbs (431 kg)
Warrranty
Assembly
770MX Assembly is available for $2,995 .
X-Axis:14 in. (356 mm)
Spindle Taper: BT30
Maximum Feed Rate
Frame
PATHPILOT® Controller
80GB program memory
Warrranty
Assembly
770MX Assembly is available for $2,995.
