8L Advanced EDU Bundle
8L CNC Lathe This product is required for the machine. $7,995.00
8L Lathe Stand This product is required for the machine. $1,550.00
8L Machine Stand Coolant kit This product is required for the machine. $395.95
8L Printed Manual $19.95
8L Lathe PathPilot Operator Console This product is required for the machine. $1,795.00
Waterproof Mini-Keyboard This product is required for the machine.
Waterproof Mouse This product is required for the machine.
Deluxe Professional Lathe Tool Kit $155.95
3-Piece STFCR Boring Bar Set $144.95
5C Round Collet Set (35 Pcs.) - Inch $295.00
Interchangeable Point Live Center Set $114.95
Huot 5C Collet Rack $40.95
4 in. Precision 4-Jaw Chuck (5C Mount) $199.00
4 in. Precision 3-Jaw Chuck (5C Mount) $229.95
0XA Tool Holder Kit for 8L $180.00
Stop-Loc Setup Tool $19.95
Digital Micrometer (0-1 in.) $59.95
Digital Caliper (0-6 in.) $27.95
Haimer CENTRO Precision Centering Device $725.00
8L CNC Lathe Extended Warranty $695.00
More Info Stock: In Stock
* Required Fields
TECHNICAL SPECIFICATIONS
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Diameter: 0.9 in.(22 mm)
Travel: 2.2 in.(55 mm)
X-Axis: 4.5 in.(114 mm)
Motion
Accessories
Available Accessories:
  • Full Enclosure (Standard)
PATHPILOT® Controller
Features:
  • User-friendly design
