Carbide Insert for Aluminum and Plastic - Center Cut End Mill 17 mm 10-Pack
$174.00
0.3 lbs.
Only 2 left
Package of 10 carbide inserts for aluminum and plastic for the 17 mm center cut end mill.
- ISO Code/Manu. Code: QOGT0830R-G1
- ANSI Code: NA
- Type: Cemented Carbide
- Grade: HTi10
- Comparable ISO Grade: N05-N25
- Surface Prep: Polished
- Cross Reference: Mitsubishi
- Applications: Aluminum/Non-Ferrous
