CCMT 2(1.5)1 Insert 10-Pack
$49.29
0.01 lbs.
The CCMT 2(1.5)1 Insert is a positive lathe insert with chipbreaker recommended for semi-finishing of steel
Package of 10 Lathe Inserts
- ISO Code/Manu. Code: CCMT 06024-HM
- ANSI Code: CCMT2(1.5)1-HM
- Type: Cemented Carbide
- Grade: YBC251
- Comparable ISO Grade: P10-P30
- Surface Prep: CVD
- Shape: 80 Rhombus (C)
- Clearance Angle: 7 (C)
- Tolerance: Class M (M)
- Type: Single Sided (T)
- Insert I.C.: .250 in. (2)
- Thickness: .094 in. (1.5)
- Corner Radius: .016 in. (1)
Notes: Lathe, General Purpose
