$309.00
0.25 lbs.
The DIJET® QM Mini Modular Insert High Feed End Mill is designed for high feed milling of steel and other ferrous materials
The QM mini is a multi-purpose cutter that can high feed, square up and finish. A variety of inserts all fit into the same body allowing you to machine a vast majority of materials, while being economical.
  • Cutting Diameter: 1/2 in.
  • Compatible Inserts:
INSERT CODE DESCRIPTIONCorner Radius PN
EOMT060210ZERHigh Feed Milling - General Purpose <50Rc1.0 38161-10
EOMW060210ZERHigh Feed Milling- Unfavorable Conditions <50Rc1.0 37992-10
EOHW060210ZTRHigh Hardened Steel Milling >50Rc 1.037996-10
EOHW060220ZTRHigh Hardened Steel Milling >50Rc2.037997-10
ZOMT060202ZERShoulder Milling0.237993-10
ZOMT060204ZERShoulder Milling0.437994-10
ZOMT060208ZERShoulder Milling0.837995-10
  • No. of Inserts: 3
  • Thread: M6 x 1
  • Insert Wrench: 35626
  • Insert Screw: 38162
Includes: Insert Screw (x3) and Insert Wrench. Inserts Sold Separately.
