Disc Spring, 40mm x 20.4mm x 3.1mm
$2.29
0.1 lbs.
Currently Out of Stock
Drawbar preload springs for 1100MX and 770MX BT30 spindles. 16 disc springs are required for each spindle. Note: If replacing a cracked spring, replace the whole set.
Outer Diameter | 40mm |
Inner Diameter | 20.4mm |
Free Height | 3.1mm |
Material | Alloy Steel |
Compatible with:
- 1100MX Spindle
- 770MX Spindle
