Passive Probe - Probe Only
$415.00
The Passive Probe - Probe only is an affordable probe for locating and digitizing, suitable for hobbyist/occasional use
Our passive probe is an affordable option for occasional and hobby use. Suitable for edge finding, digitizing, and other basic probing procedures
- Normally closed sensing logic
- Compatible with Renishaw M4 Stylus family
- Stainless steel probe tip
- Interfaces with machines mill using a 5 pin DIN connector.
- Replacement for PN: 32310
Use with replacement tip PN 31899
Note: This product is not compatible with the 1500MX CNC Mill.
Specifications
Measuring Direction | ±X, ±Y, & +Z |
Repeatability | 0.00059 in. (0.015 mm) |
Maximum Over-Travel In +Z | + .1968 in. (5.0 mm) |
Maximum Angular Displacement | ± 15° |
Radial (X-Y) Trigger Force | 30-60 g |
Axial Trigger Force | 500 ± 30 g |
Water Resistance | IP66 |
Shank size | 10mm |
