Professional Metalworking Gauge Set
$379.95
6 lbs.
The Professional Metalworking Gauge Set is a 7-piece kit containing the most commonly-used metrology tools. Caliper and micrometer are IP54 fluid resistant.
What's In The Box?
  • 6 in. caliper
  • 0-1 in. digital micrometer
  • Premium dial test indicator
  • Dial indicator
  • Magnetic base
  • 123 block, qty 2
Get started with commonly used metrology tools from iGAGING. This 7-piece set includes a set of calipers, a micrometer, a dial-test indicator set, 1in. dial indicator, and 1-2-3 blocks.
Specifications
0-1 in. (0-25 mm) Micrometer:
Crisp, clear, easy-to-read LCD display, accurate to 0.00016 in. Hardened and ground spindle with carbide anvil ensure durability and accuracy. Comes in a padded case with an adjustment wrench, instructions booklet, and extra battery.
Features:
  • IP54 Splash Water, Oil and Dust Resistant
  • Large LCD Display
  • Absolute & Incremental Modes
  • Automatic Switch Off
  • Accuracy +/- 0.00016 in.
  • Range 0-1 in. /0-25 mm
  • Resolution 0.00005 in. /0.001mm
  • Carbide Measuring Surfaces
0-6 in. (0-150mm) Caliper:
Easy to read, large, LCD display available. 4 digits decimal mode or 1/128" fractional display.
This caliper offers IP54 resistance protection against dust splash water and oil.
Features:
  • Easy read LARGE display (2-3/8 in. x 7/8 in. )
  • Hardened stainless steel
  • Precision lapping finish
  • Range: 0-6 in.
  • Accuracy: 0.001 in.
  • Repeatability: 0.0005 in.
  • Resolution: 0.0005 in. / 0.01 mm / 1 / 128 in.
Premium Dial Test Indicator, 0.030 in. - 400-030
Features:
  • IP65
  • Range: 0.030 in.
  • Graduation: 0.0005 in.
  • Reading: 0-15-0
  • Face Dia.: 1-1/4 in.
  • Satin chrome finish
  • Universal positioning contact
  • 3-side standard dovetail mount
  • Jeweled movement
  • 5/32 in. & 3/8 in. dovetail extensions included
Premium Dial Indicator 0-1.000 in.
This 1in. stroke dial indicator features large, easy to read numbers and crisp graduations. Each revolution is 0.100 in., indicated by the revolution counter. The resolution is 0.001 in. There is a mounting lug on the back of the case.
Features:
  • Easy to read 2-1/4 in. white face with black markings
  • Crisp graduations
  • Durable satin chrome finish
  • Spindle rack pinions and gear trains are made of high-quality steel components ensuring long life
  • Vertical lug back configuration
  • Graduations: 0.001 in. per line, 0.1 in. per revolution
1-2-3 Blocks
Features:
  • Matched pair & professional quality
  • Precision Ground steel
  • Case Hardened on all six sides
  • 1 x 2 x 3 in. 2pcs pair set
  • Squareness on all sides within 0.0001in.
  • 23 holes for easy clamping
  • 5 tapped 3/8 in.- 16 TPI and 18 plain
  • Useful in layout or grinding work
  • Hardened and ground steel
  • Matched accuracy of .0002 in.
  • Accuracy of .0003 in. per inch
Magnetic base
Features:
  • Magnetic base holder with central locking switch
  • Shaft mounting Ø8mm for dial indicators and probes
  • Dovetail clamping for swivel probes
  • 176 lbs. (80 kg) magnetic holding power
  • Body equipped with mechanical central clamping device
