TCMT222 - High Temp Alloys - 10-Pack
$99.50
0.02 lbs.
The C2 Insert, TCMT222 is for the 3/8 in. Lathe Toolholder
Package of 10 TCMT222 Indexable carbide lathe insert, grade C2. C2 is well suited for cast iron, non ferrous, and high temperature alloys.
- Shape: Triangle (T)
- Clearance Angle: 7 (C)
- Tolerance: Class M (M)
- Type: Single Sided (T)
- Insert I.C.: .250" (2)
- Thickness: .125" (2)
- Corner Radius: .031" (2)
- ISO Code/Manu. Code: TCMT110308
- ANSI Code: TCMT222
- Type: Cemented Carbide
- Grade: C2
- Comparable ISO Grade: C2
- Surface Prep: Uncoated
- Cross Reference: Generic
Notes: Lathe, Aluminum/Non-Ferrous/Cast Iron
