TTS SuperFly Cutter Kit
$145.00
The TTS SuperFly Cutter includes: fly cutter body, tool bar, two general purpose carbide inserts, two polished carbide inserts for aluminum machining, insert Screw, wrench and anti-seize.
TTS SuperFly Cutter Kit for the Deluxe Package. Fly Cutter kit with modern insert geometries, specially designed for maximum performance on 3hp spindles.
- Adjustable to 3 in. (75 mm) Cutting Diameter
- Includes tool bar for SEHT Insert
- 1.8 in. (46 mm) Height
- TTS Fly Cutter Body with ATC Geometry
Kit includes:
- Fly Cutter Body
- Tool bar
- Two General purpose carbide inserts
- Two polished carbide inserts for aluminum machining
- Insert Screw
- Wrench
- Anti-seize
Support
Learn More
