VersaGrip™ Vise Jaws - Mitee-Bite - Compatible with Tormach 4 in. and 5 in. vises
$185.00
6 lbs.
Currently Out of Stock
COMPATIBLE WITH TORMACH 4 in. and 5 in. VISES
This system can accommodate a wide range of part sizes as well as holding multiple parts in a single cycle. The hardened (51-53 RC) VersaGrip™ has penetrating teeth designed to bite into your workpiece preventing lateral and horizontal movement. These grips will hold flame cut parts, castings, even parts with a negative draft!
STEEL VISE JAW SET (Set includes 4 VersaGrips™ with M5 Screws)
Vise (metric) | 4 in. /6 in. (100mm/150mm) |
A (metric) | 6.0 in. (150 mm) |
B (metric) | 1.88 in. (47.75 mm) |
C (metric) | 1.0 in. (25.4 mm) |
D (metric) | 2.5 in. / 3.125 in. (63.5 mm/ 79.375 mm) |
E (metric) | .688 in. / .8 in. (17.47 mm / 20.32 mm) |
