xsTECH Router 4th Axis Kit
$595.00
7 lbs.
xsTECH 4th Axis Kit
What's in the box:
- 4th Axis Main Unit
- Tailstock
- Setup Bar
- ER32 Nut
- ER32 - 16mm Collet
- ER32 - 20mm Collet
- ER32 - 1/2 in. Collet
- ER32 - 3/4 in. Collet
- ER32 Hook Spanner
- Wrench (38mm)
- 5mm Hex Wrench
- Setup Bar Tool
Add a 4th axis kit to your xsTECH and get positional 3+1 and full 4th axis capabilities.
Note: Only works on machines with dual DIN connections.
Specifications
Specifications:
- ER32 Spindle can hold workpieces up to .75 in. / 19mm in diameter
- Includes integrated Homing switch for position referencing
- Adjustable tailstock for workpieces up to 8 in. / 200mm in length
- Includes tailstock, setup bar, 4 ER32 Collets, and wrenches
