Deluxe Lathe Tool Starter Kit
$995.95
20 lbs.
The Deluxe Lathe Tool Starter Kit is a deluxe starter kit of lathe tools for the 15L Slant-Pro Lathe, recommended for Quick Change Post or Turret
Recommended Lathe Tool Starter Kit for use with Quick Change Tool Post or Turret.
Includes turning, boring, and hole-making tools, inserts and drills.
- (1) RH Turning Tool: SCLCR-12-4B (PN 35650)
- (1) LH Turning Tool: SCLCL-12-4B (PN 35651)
- (1) RH Turning Tool: SCKCR-12-4B (PN 35652)
- (1) NH Turning Tool: SCMCN-12-4B (PN 35654)
- (1) RH Turning Tool: SCBCR-12-4B (PN 35655)
- (1) RH Turning Tool: SCSCR-12-4B (PN 35653)
- (1) RH Boring Bar: S12S-SCLCR-4 (PN 35648)
- (1) RH Boring Bar: S08M-SCLCR-2 (PN 35640)
- (1) RH Boring Bar: S06H-SCLCR-2 (PN 35632)
- (1) RH Cutoff/Parting Tool: SGTHR 19-4 (PN 33347)
- (3) ER16 Collet Chuck (PN 34057)
- (1) 22 pc. ER16 Collet Set (PN 31688)
- (1 pkg of 10) CCMT 432 Insert (PN 35657)
- (1 pkg of 10) CCMT 2(1.5)1 Insert (PN 32419)
- (1 pkg of 10) GTN-4 Insert (PN 32841)
- (1) 1/16"-1/2 in. Screw Machine Drill Set, 29 pcs. (PN 37331)
- (1) #1-#6 Center Drill Set, 6 pcs. (PN 31071)
Specifications
