High Speed Spindle Kit for Tormach 1100
$1,925.00
23 lbs.
Only 1 left
The High Speed ER20 Spindle Kit for Tormach PCNC 1100 is Water Cooled, 10000 - 24000 RPM
Comparability
  • Series 2 and Series 3 PCNC 1100 mills and 1100M mills (not compatible with with Series 1, or MX mills).
Includes 2 programmable memory sticks
Replacement spindle cartridge for 24000RPM water-cooled spindle kit.
  • Speed Range: 10000-24000 RPM
  • Power: 1.5 HP (1.1 kW)
  • Voltage: 230V
  • Spindle Taper: ER20
  • Cartridge Diameter: 80 mm
  • Water line: Compression fittings for 6 mm ID tubing*
Includes balanced ER20 retention nut. ER20 Collets sold separately. Not compatible with Tormach ATC.
NOTE: QC Motor Connect Kit - "NOT REQUIRED FOR M SERIES MACHINES OR PCNC MACHINES THAT PREVIOUSLY HAD QC KIT INSTALLED FOR RAPIDTURN USE"
