ABOUT G-CODE PROGRAMMING LANGUAGE
EXAMPLE: G01 X3 is a valid line of code with two words: G01 is a command: the machine should move in a straight line at the programmed feed rate. X3 provides an argument value: the value of X should be 3 at the end of the move.
There are two commands (M02 and M30) that end a program. A program can end before the end of a file. If there are lines in a file after the end of a program, they’re not meant to be executed in the normal flow (they’re generally parts of subroutines).
You can add comments or messages to lines of G-code to help clarify the intention of the programmer: to embed a comment in a line, use parentheses; to add a comment to the end of a line, use a semicolon.
 NOTE: The semicolon is not treated as the start of a comment when it’s enclosed in parentheses.
Comments can appear between words, but they can’t be between words and their corresponding parameter.
EXAMPLE: S100 (set speed) F200 (feed) is okay, but S (speed) 100F (feed) is not.
