BINARY OPERATORS REFERENCE
- * / MOD
- EQ NE GT GE LT LE
- AND OR XOR
EXAMPLE[2.0 / 3 * 1.5 – 5.5 / 11.0] is equivalent to [[[2.0 / 3] * 1.5] – [5.5 / 11.0]]
which is equivalent to [1.0 – 0.5]
which is
0.5
