CONDITIONAL SUBROUTINES REFERENCE
IF/ENDIF
If/endif example:
o100 sub
o110 if [#2 GT 5]
(some code here)
o110 endif
(some more code here)
o100 endsub
IF/ELSEIF/ELSE/ENDIF
If/elseif/endif example:
F100
F200
F150
o102 endif
