LOOPING SUBROUTINES REFERENCE
DO/WHILE
Do/while loop example:
o100 do
(debug, parameter 1 = #1)
o110 if [#1 EQ 2]
o110 endif
(some code here)
o100 while [#1 LT 3]
M02
WHILE/ENDWHILE
While/endwhile example:
(draw a sawtooth shape)
F25 (set a feed rate)
o101 while [#1 LT 10]
G01 X0
G01 Y[#1/10] X1
o101 endwhile
M02 (end program)
- A return or endsub not within a sub definition
- A label on repeat which is defined elsewhere
- A label on while which is defined elsewhere and not referring to a do
- A label on if defined elsewhere
- A undefined label on else or elseif
- A label on else, elseif or endif not pointing to a matching if
- A label on break or continue which does not point to a matching while or do
- A label on endrepeat or endwhile no referring to a corresponding while or repeat
