G-CODE FORMATTING REFERENCE
  • (Optional) Block delete character (/)
  • (Optional) Line number
  • Any number of words, parameter settings, and comments
  • End of line marker (carriage return or line break)
Spaces and tabs are allowed anywhere on a line of code and do not change the meaning of the line, except inside comments. Blank lines are allowed in the input, but they’re ignored. Input is not case sensitive (except in comments), so any letter outside a comment may be in uppercase or lowercase without changing the meaning of a line.
EXAMPLE G00 x +0. 12 34y 7 is equal to G00 x+0.1234 y7
A line may have:
PathPilot sometimes ignores things it doesn’t understand. If a command doesn’t work as expected, or does nothing, make sure that it’s correctly typed. PathPilot doesn’t check for excessively high machining feeds or speeds, and it doesn’t detect situations where a legal command will do something unfortunate (like machining a fixture).
LINE NUMBERS
  1. The letter N
Line numbers may be repeated, or used out of order, but that’s rare in normal practice. A line number isn’t required, and is often omitted.
WORDS
  1. A letter other than N or O
  2. A real value
LETTERS
  • A: A-axis of mill
  • B: B-axis of mill
  • C: C-axis of mill
  • D: Tool radius compensation number
  • F: Feed rate
  • G: General function
  • H: Tool length offset index
  • I: X-axis offset for arcs, or X offset in a G87 canned cycle
  • J: Y-axis offset for arcs, or Y offset in a G87 canned cycle
  • K: Z-axis offset for arcs, or Z offset in a G87 canned cycle
  • L: Number of repetitions in canned cycles and subroutines, or key used with G10
  • M: Miscellaneous function
  • N: Line number
  • O: Subroutine label number
  • P: Dwell time in canned cycles, dwell time with G04, key used with G10, or tapping depth in M871 through M874
  • Q: Feed increment in a G83 canned cycle, or repetitions of subroutine call
  • R: Arc radius, or canned cycle retract level
  • S: Spindle speed
  • T: Tool selection
  • U: Synonymous with A
  • V: Synonymous with B
  • W: Synonymous with C
  • X: X-axis of mill
  • Y: Y-axis of mill
  • Z: Z-axis of mill
VALUES
    1. An optional plus or minus sign
    2. Zero to many digits
    3. (Optional) One decimal point
    4. Zero to many digits
NOTE: PathPilot only keeps 17 significant figures, which is enough for all known applications.
ORDER OF EXECUTION
If a parameter setting of the same parameter is repeated on a line (like #3=15 #3=6), only the last setting takes effect. It’s illogical, but not illegal, to set the same parameter twice on the same line.
The order of items on a line doesn’t determine the order of execution on the commands.
Three types of items’ order may vary on a line (as given earlier in this section):
  • Parameter Setting If it’s reordered, there is no change in the meaning of the line unless the same parameter is set more than once. In this case, only the last setting of the parameter takes effect.
EXAMPLE When the line #3=15 #3=6 is interpreted, the value of parameter 3 is 6. If the order is reversed to #3=6 #3=15 and the line is interpreted, the value of parameter 3 is 15.
EXAMPLE
The order of execution of items on a line is critical to safe and effective mill operation. If items occur on the same line, they are executed in a particular order. To impose a different order (like to turn coolant off before the spindle is stopped), code the commands on separate blocks.
  3. Set feed rate (F)
  4. Set spindle speed (S)
  5. Special I/O (M62 to M68)
NOTE: This is not supported.
  1. Change tool (T)
  6. Operator defined commands (M100 to M199)
  7. Dwell (G04)
MODAL GROUPS
EXAMPLE If coolant is turned on (M07 or M08), it stays on until it is explicitly turned off in the program (M09).
A few G-codes and M-codes are non-modal. These codes have effect only on the lines on which they occur.
EXAMPLE Dwell (G04) is non-modal.
Modal commands are arranged in sets, called modal groups. Only one member of a modal group may be in force at any given time. In general, a modal group contains commands for which it is logically impossible for two members to be in effect at the same time.
EXAMPLE Inch units (G20) vs. millimeter units (G21).
Modal groups for G-codes are as follows:
  • Group 1 {G00, G01, G02, G03, G33, G38.x, G73, G76, G80, G81, G82, G84, G85, G86, G87, G88, G89} motion – This is a group of G-codes for motion called current motion mode — one is always in effect.
  • Group 2 {G17, G18, G19, G17.1, G17.2, G17.3} plane selection
  • Group 3 {G90, G91} distance mode
  • Group 4 {G90.1, G91.1} arc IJK distance mode
  • Group 5 {G93, G94} feed rate mode
  • Group 6 {G20, G21} units
  • Group 7 {G40, G41, G42, G41.1, G42.1} cutter radius compensation
  • Group 8 {G43, G43.1, G49} tool length offset
  • Group 10 {G98, G99} return mode in canned cycles
  • Group 12 {G54, G55, G56, G57, G58, G59, G59.1, G59.2, G59.3} coordinate system selection
  • Group 13 {G61, G61.1, G64} path control mode
  • Group 14 {G96, G97} spindle speed mode
  • Group 15 {G07, G08} lathe diameter mode
Modal groups for M-codes are as follows:
  • Group 4 {M00, M01, M02, M30, M60} stopping
  • Group 7 {M03, M04, M05} spindle turning
  • Group 8 {M07, M08, M09} coolant (special case: M07 and M08 may be active at the same time)
  • Group 9 {M48, M49} enable/disable feed and speed override controls
  • Group 10 {operator defined M100 to M199}
Non-modal G-codes are as follows:
