SET WORK OFFSETS (G10 L2)
To define the origin of a work offset coordinate system, program: G10 L2 P~
- P~ is the number of coordinate system to use (G54 = 1, G59.3 = 9)
The G10 L2 P~ command doesn’t change from the current coordinate system to the one specified by P. Use G54 through G59.3 to select a coordinate system. The coordinate system whose origin is set by a G10 command may be active or inactive at the time the G10 is executed. If it’s currently active, the new coordinates take effect immediately.
EXAMPLE – If a G92 origin offset was in effect before G10 L2, it continues to be in effect after.
TROUBLESHOOTING
It’s an error if:
- The P number does not evaluate to an integer in the range 0 to 9
- An axis other than X or Z is programmed
